Texas Department of Licensing and Regulation Adopts Administrative Rules
The Texas Commission of Licensing and Regulation recently adopted a new rule regarding the Electricians Program (16 Texas Administrative Code Chapter 73, §73.71). The adopted rule implements House Bill (HB) 1342, 86th Legislature, Regular Session (2019). Section 2 of HB 1342 authorizes the Texas Commission of Licensing and Regulation and the Department’s Executive Director to issue a restricted license to a person as an alternative to denying, revoking, suspending, or refusing to issue a license. Section 2 also authorizes the Department to impose reasonable conditions on a holder of a restricted license.
The adoption justification was published in the January 24, 2020, issue of the Texas Register (45 TexReg 537). This justification states that the adopted rule contains three subsections:
- Adopted rule §73.71(a) requires the holder of a restricted license to comply with the conditions imposed upon the license by the Commission or Executive Director. A holder of a restricted license who does not comply with the terms of a restricted license may be subject to an administrative penalty or other sanction as allowed by Texas Occupations Code, Chapter 51.
- Adopted rule §73.71(b) requires a licensee to use reasonable care to ensure that a person under his or her supervision who holds a restricted license complies with the conditions placed on that license. This subsection simply restates Texas Occupations Code §51.357(d) as enacted by HB 1342.
- Adopted rule §73.71(c) requires the holder of a restricted license to inform his or her employer of the conditions placed on the license before performing any work under that license. Potential conditions that could be imposed by the Commission or Executive Director pursuant to Texas Occupations Code §51.357(b) are that the license holder be subject to close supervision, or be allowed to work in only nonresidential settings. Because HB 1342 and adopted rule §73.71(b) require supervisors to use care to ensure that persons under their supervision with restricted licenses comply with the terms of licensure, it is reasonable that licensees be required to inform their employers of those conditions.
The updated rule chapter will be made available upon its effective date of February 1, 2020.
