State Construction Unemployment Down in Every State
Nebraska, Indiana, Utah, Georgia, and Oklahoma had their lowest December estimated construction unemployment rate on record.
The not seasonally adjusted (NSA) national construction unemployment rate plunged 4.6% in December 2021 from 2020, down from 9.6% to 5%, while all 50 states had lower unemployment rates over the same period, according to a state-by-state analysis of U.S. Bureau of Labor Statistics data released by Associated Builders and Contractors (see Figure below). This substantial improvement occurred even as the omicron COVID-19 variant was sweeping the nation.
While not fully recovered to its pre-pandemic level, national NSA construction employment was 163,000 higher than in December 2020. Seasonally adjusted construction employment was only 96,000, or 1.3%, below its February 2020 peak, before the impact of the COVID-19 pandemic began to affect the employment numbers. This beat national seasonally adjusted nonfarm payroll employment, which, though improving, was still 2.2% below its February 2020 peak as of December 2021.
The national NSA construction unemployment rate of 5% was unchanged in December 2021 from its December 2019 reading. Over that same period, 34 states had lower construction unemployment rates, and 16 states had higher rates.
“The construction industry is making impressive progress despite continuing supply chain issues, which include extended delivery times and shortages of some building materials and appliances,” said Bernard M. Markstein, president and chief economist of Markstein Advisors, who conducted the analysis for ABC. “Employers are also coping with difficulties finding skilled workers. The normal winter slowdown in construction activity is, at least temporarily, relieving some of the stress from these challenges.”
The Top Five States
The five states with the lowest December 2021 estimated NSA construction unemployment rates were:
1. Nebraska, 1.3%
2. Indiana and Utah (tie), 1.5%
4. Georgia, 1.6%
5. Oklahoma, 2%
All five states had their lowest December estimated NSA construction unemployment rate on record.
The Bottom Five States
The states with the highest December 2021 estimated NSA construction unemployment rates were:
46. New Jersey, 8.3%
47. Michigan, 8.6%
48. North Dakota, 9%
49. New York, 9.5%
50. Alaska, 10%
Alaska posted its lowest December estimated NSA construction unemployment rate on record.
For more information on calculating unemployment rates and what they measure, visit ABC's website.
