Keep Commercial Lighting Projects Code Compliant with ARISTA
Introducing a customizable, contractor-focused smart lighting solution that’s easy to install and designed for out-of-the-box code compliance.
As states and municipalities across the country work to implement new energy-efficient building standards, design engineers are tasked with finding solutions that meet local guidelines while catering to project needs.
The new ARISTA™ Advanced Lighting Control System offers a flexible solution that’s easy to install and promotes code compliance in a range of commercial applications.
Out of the box, ARISTA meets or exceeds ASHRAE 90.1-2016, IECC 2018 and Title 24-2019. The system’s modular components (e.g., controllers, occupancy sensors, daylight harvesting sensors, dimmers) allow design engineers and design-build contractors to select the functionality needed within a project, then hand off specific installation specifications to contractors and commissioners.
For example, a local ordinance may require lights to dim when a certain threshold of ambient daylight is detected or for lights in limited-use spaces to shut off automatically after a given period. Bluetooth® mesh networking technology and the ARISTA app streamline this process and give installers the ability to quickly configure devices, set run levels, create ON/OFF schedules and more.
ARISTA components work together to elevate indoor environments for occupants while reducing energy use and adhering to building codes.
Ready to see ARISTA in action? Contact your local Intermatic representative today to schedule a demo of this exciting new solution!
Sponsored by:
