• Product Spotlight
    Raceway for workstations Eclipse 2 is an intermediate-size, dual-channel workstation raceway that accommodates power and data/communications applications with an integral, one-third and two-thirds divider. Its 27/16-in. profile allows up to seven 12 AWG wires in the smaller channel and 12 UTP cables at 40% fill in the larger channel.The Wiremold Co.Circle 305 Emergency communications center The Millennium
    Dec. 1, 2001
    The Wiremold Co.
    Circle 305Emergency communications center
    The Millennium System Master provides fully supervised control of plant notification systems for personnel evacuations and nonemergency communications. It features 27 built-in tones, can be operated by a hand-held microphone, and stores up to four 5-sec, field-recordable voice messages for playing over remote speakers.
    Edwards Signaling
    Circle 303Communications system
    Safepath4 is a communications system that allows facilities to save equipment, installation, and maintenance costs by combining supervised fire and emergency notification and warning systems with a public address system that can play background music and announcements.
    Wheelock
    Circle 300Smoke detector
    Acclimate Plus is a smoke detector that constantly monitors its environment for temperature, smoke, electrical noise, and air-particulate levels. It can report an alarm within 1 sec and turn on all outputs within 2 sec. It uses the company's Flash-Scan protocol, which groups and scans 10 devices at a time, significantly improving response time.
    Notifier
    Circle 304Fiber connector system
    In this fiber connector system, an MT-RJ connector terminates two fibers using a plug similar in size and shape to the 8-position RJ-45 modular plug used with UTP copper network wiring. This polarized, dual-fiber connector supports a full-duplex (transmit and receive) link in a single connector.
    Amp Netconnect
    Circle 301Compact smoke detector
    The Simplex TrueAlarm Laser Compact is an air-aspiration smoke detector that provides fire detection in small, high-risk areas, such as telecommunications facilities, clean rooms, and data-processing cabinets. Because it detects extremely low concentrations of smoke, it provides early-warning detection.
    SimplexGrinnell
    Circle 302
    EC&M Staff
