Product News
Energy and power quality meters
Designed for monitoring key distribution points and sensitive loads, the ION 7550 and 7650 energy and power quality meters combine power-quality compliance reporting functions, sampling rates as high as 1,024 samples per cycle, and enhanced communications options. The meters feature an increased onboard memory that allows the devices to store more waveforms, event records, and load trend data. They're also equipped with a new ANSI optical port for secure access to billing data or historical event records, setpoint alarming and control capabilities, a variety of on-board analog and digital I/O, and a large high-visibility display.
Power Measurement
Circle 150
UPS
As an addition to this manufacturer's DPP series, this single-phase uninterruptible power supply (UPS) is a true, online double-conversion system that provides clean, continuous power for critical AC loads. The UPS system incorporates input and output isolation transformers; a dual-source, fully controlled and rated static switch; and a customer-specified internal or remote manual bypass switch. It uses a digitally controlled pulse width modulated inverter design that offers advanced communications and control capability, and it features a man-machine interface panel with LCD touch screen that enables continuous monitoring of system status and displays the status on an operational mimic diagram on the LCD panel.
Ametek Solidstate Controls
Circle 152
UPS with kenetic power cell technology
This 1,2000kVA, 960kW, 60 Hz uninterruptible power supply (UPS) system with kinetic power cell technology offers minimal input current distortion, transient protection, and harmonic distortion cancellation. The system provides high-speed voltage regulation and power factor improvement with a full-rated, continuous-duty static bypass switch and local emergency power off. It also includes integrated alarms for all critical components, a programmable auto restart, self-diagnosis, a bi-directional inverter, an RS-232 or RS-485 serial connector, and a 56 kbps modem. Overall system supervision is possible via remote monitoring.
Caterpillar
Circle 151
