Product News
Hazardous location photocell The PCD2 series of hazardous location photocells carries a NEMA 4X rating for protection against corrosion, windblown dust and rain, splashing water, hose-directed water, and external icing. The photocells automatically turn fixtures on at a 3-footcandle brightness and off at 8 footcandles. They can fit through standard 0.5-in knockouts and can be used with 120V, 208V,
Sept. 1, 2004
5 min read
The PCD2 series of hazardous location photocells carries a NEMA 4X rating for protection against corrosion, windblown dust and rain, splashing water, hose-directed water, and external icing. The photocells automatically turn fixtures on at a 3-footcandle brightness and off at 8 footcandles. They can fit through standard 0.5-in knockouts and can be used with 120V, 208V, 240V, and 277V incandescent or fluorescent 50/60 Hz fixtures with 35W to 400W HID lamps.
Appleton
Circle 206
Lighting fixtures
Available in three models, the TP series of lighting fixtures has an internal accessory cartridge, which takes a wide range of C-size accessories like color filters, spread lenses, light-blocking screens, and louvers. The TPM38 metal halide fixture is available in 70W or 100W, with a lamp-life of 10,000 hours. The TP36 fixture has a snap-in socket that accepts PAR36 and AR111 lamps as high as 75W. The line voltage TP38 takes any PAR38 energy-conserving, medium screw-based lamp. Each lamp is made of extruded and cast aluminum and is available in graphite, platinum, silver, black, and white finishes.
Lighting Services
Circle 202
Battery capacity analyzers
Available in two models, these battery capacity analyzers can complete a test in about 6 sec to determine the serviceability of a battery for use in emergency lighting, UPS backup, service, research and engineering, test, and manufactured bench applications. The model 601 can identify the capacity of 6V and 12V lead acid batteries, and the model 602 works with 24V and 36V lead acid batteries that may have be deteriorated or are defective. Both analyzers measure and digitally display the percentage of capacity left in the battery.
B&K Precision
Circle 204
Lead-free cables
One of these riser-rated, low-smoke, zero-halogen, lead-free cables can replace the interconnect assemblies and installation cables that are used to network OEM active equipment. They come in foil twisted-pair and unshielded twisted-pair in solid and stranded conductor category copper cables.
Berk-Tek
Circle 200
Pulse-start lamp
Designed for street, outdoor, and parking lot applications, the Uni-Form H75 system 320W pulse-start lamp uses a compact tubular shape and is designed specifically for horizontal operation. The system is rated for 30,000 initial lumens and 23,000 mean lumens, and has 20,000 hours of rated life. The lamp produces 70% more effective lumens than high-pressure sodium systems.
Venture Lighting
Circle 207
Hotbus
The HotBus digital serial communications system offers continuous bearing temperature monitoring with as many as 256 bearing sensors on a single twisted-pair cable. The system allows user-adjustable relative ambient and absolute trip points for each sensor. They can be stand-alone or connected to relay control units to provide automatic shutdown. Software is provided for system test, system status, and uploading sensor names and logging/trending bearing temperatures and alarms.
4B Components
Circle 209
Cord grips
These metallic cord grips feature smooth, rounded interior edges that allow the insertion of cords and cables that range from 0.079-in. to more than 2-in. in diameter without binding or scraping of insulation. The hub surfaces of the grips are fully threaded for assembly in clearance or threaded holes with or without locknuts, respectively, and a thermoplastic polymer elastomer inner seal ensures a liquid-tight seal around all cables and wires in temperatures from -40°C to more than 100°C.
Heyco
Circle 205
Hi-pot testers
The H111 and H216 bench top safety testers are designed for production and lab testing. The testers can be used for AC and DC voltage withstanding tests as high as 6kV on various types of electrical equipment and components. They can store as many as 10 different tests and programs that contain as many as 16 steps, which can be initiated at the push of a button.
AEMC
Circle 203
Tool sets
The 18-piece Journeyman set contains a basic variety of screwdrivers and nut drivers, journeyman pliers, a power-return rule with a magnetic tip, an adjustable wrench, protective eyewear, and a 10-pocket leather tool pouch. The 41-piece Journeyman tool set includes everything in the 18-piece set plus more screwdrivers and nut drivers, strippers/cutters, 120-ft of flat steel fish tape, a magnetic torpedo level, and a 10-pocket canvas tool bag with a leather bottom. The 14-piece electrician tool set offers a variety of screwdrivers and pliers, a wire stripper/cutter, double-sided power return rule, protective eyewear, and an 8-pocket leather tool pouch. The 28-piece electrician tool set has everything in the 14-piece set with more basic screwdrivers, nut drivers, and pliers; a magnetic torpedo level, crimping tool, adjustable wrench, utility knife, and a 16-in. canvas tool bag.
Klein Tools
Circle 201
DC power supplies
Available in three models, the Telemecanique Phaseo DC power supplies have integrated overload, short-circuit, overvoltage, and undervoltage protection. They're now more compact with a high degree of output voltage stability, and come in a modular format to install in control panels. The single-phase power supplies measure 2.25 in. × 2.75 in and provide the DC voltage necessary for applications with 100VAC to 240VAC and 12VDC to 24VDC. The 3-phase ABL7UPS is available in 10A, 20A, and 40A and is designed to accept 420VAC to 520VAC and output 24VDC. The ABL7CEM measures 3-in. × 1.75 in. × 2.75 in. and it accepts 100VAC to 240VAC, and outputs 24VDC, and can accept dual frequencies that cover 40 Hz to 50 Hz in one unit.
Square D/Schneider Electric
Circle 208
Reference poster
Created for engineers, designers, and contractors, the Codesign Time Saver is a desktop or wall reference sheet that provides at-a-glance information. Made of heavy, non-glare material, this 22-in. × 28-in. sheet contains six motor circuit design schedules; single- and 3-phase feeder schedules; a schedule for general purpose dry type transformers with primary and secondary information; a 40%, 53%, and 60% conduit fill schedule; a table of conductor dimensions; properties for bare and insulated conductors; GEC and EGC tables; HID lamp wattages; GFCI receptacle locations; and a complete list of the new NEC article numbers.
Codesigner
Circle 210
