January 2002 Products of the Week
Power-monitoring server The Powerlogic power server combines an industrial-rated computer, power monitoring software, an Ethernet gateway, and a Web server in one system. The server can provide local monitoring as a standalone system, or gateway connectivity in a corporate-wide system. It can also transfer data in an online enterprise system. Square D For more information, visit www.powerlogic.com
Jan. 1, 2002
Square D
For more information, visit www.powerlogic.com or www.SquareD.com..
Thermal labeling tool
ID Pal is a thermal labeling tool that can label smooth, textured, or curved surfaces, including wire and cable. It comes equipped with electrical and datacom symbols. A wire-marking mode that includes 10 preset lengths is available for wire and cable marking. The labels provide an exposed edge for ease in removal.
Brady
For more information, visit www.bradyidpal.com.
Combination AFCI/GFCI circuit breaker
This UL-certified circuit breaker combines arc-fault circuit interrupter (AFCI) and ground-fault circuit interrupter (GFCI) protection in a single device, eliminating the need to install two devices and reducing installation time. The AFCI technology detects and clears electrical arcs that can result from damaged wiring while the GFCI protects against electrical shock.
Cutler-Hammer/Eaton
For more information, visit www.Cutler-Hammer.com.
Cost-estimating software
ProEst electrical estimating software and ProEst mechanical estimating software are Windows-based cost-estimating systems. They enable construction personnel to create, edit, and manage as many as 10,000 estimates. The systems also incorporate report generators, and include prebuilt databases that can generate standardized bids.
CMS Construction Software
For more information, visit www.proest.com..
