Product News
Shirt/jacket The Sawhorse Shirtjac features a 10-oz dark denim outer shell and a camouflage flannel inner lining. Made of 100% cotton, the shirt features two flap pockets with one pencil opening. In addition, the shirt comes in sizes from medium to double extra large.WolverineCircle 250 Electrical kit The TK-30IR electrical kit includes three core products: the DM-20 manual ranging multimeter, the
April 1, 2007
5 min read
Shirt/jacket
Wolverine
Circle 250
Electrical kit
The TK-30IR electrical kit includes three core products: the DM-20 manual ranging multimeter, the GT-15 non-contact voltage detector, and the GT-10GFI circuit tester. The DM-20 measures current of small electronic circuits and checks 9V batteries. It also measures AC/DC voltage, DC amperage, and resistance. The GT-15 is used to troubleshoot 120VAC grounded outlets. It features a light sequence that indicates correct or incorrect wiring. The GT-10GFI is used to detect voltage in outlets, lighting fixtures, circuit breakers, wires and cables, or to find a break in a wire. It provides non-contact voltage detection and activates its bright LED audible alarm if voltage is present.
Greenlee, a Textron Co.
Circle 251
freeproductinfo.net/ecm
Fastening tools
The 10.8V Impactor fastening driver and 21618 impact wrench are suitable for a range of professional fastening applications. Measuring 6-in. tall by 6½-in. long and weighing 2.2 lb, the Impactor delivers 800-in.-lb of torque. According to the company, the driver is 60% more powerful than a standard 18V drill/driver. The 21618 18V ½-in. impact wrench delivers 350 ft-lb of torque. The tool weighs 7½ lb., and its head length measures 9½ in. In addition, it comes with two 18V Bluecore NiCd batteries, a 30-min. charger, and a carrying case.
Bosch Power Tools
Circle 252
Cord grips
Snap-In cord grips are for strain-relief in limited-clearance applications inside electrical cabinets and housings. Suitable for non-liquid-tight strain-relief applications, the product allows cords and cables from 0.079 in. to more than 1 in. in diameter to be inserted through the grips. In addition, they are constructed of polyamide 6/6 nylon. Available in black, white, or matched to a color chip, they meet UL 94V-2 flammability requirements.
Heyco Products
Circle 253
Hydraulic tooling/U-dies
These hydraulic tooling and U-dies accommodate a range of electrical terminals and splices. The hydraulic crimping products include hydraulic pumps, controls and hose, heavy-duty crimp heads for shank dies, medium-duty crimp heads and hand tools for U-dies, and integrated crimp die tooling for Solistrand terminals. A portable battery-powered hydraulic unit and a self-contained power unit are also available. The crimping tools operate at 10,000 psi and, in combination with the interchangeable U-dies and heads, are suitable for crimping applications requiring up to 12 tons of crimp force. U-dies accommodate stroke options of1 in. or 1.5 in.
Tyco Electronics
Circle 254
Lighting control security package
This security package for the AuroRa wireless lighting control system provides visual alerts to neighbors and rescue vehicles during in-home emergencies. In the event of an alarm, all indoor lights controlled by the system will turn on to full brightness, while all of the entry lights controlled by the system will flash. The package includes five wall dimmers, five designer wallplate inserts, one tabletop master control, one wireless controller, and one security interface.
Lutron Electronics
Circle 255
Rotary hammer drill
The TE 7-A cordless rotary hammer drill is suitable for drilling in concrete and masonry or light chiseling. Equipped with 36V lithium-ion batteries, the drill offers an optional TE DRS-M dust removal system. In addition, it features a 5/16-in. to ¾-in. diameter optimum drilling range.
Hilti
Circle 256
Cable-pulling lubricant
Velocity ultra-low friction cable-pulling lubricant exhibits a coefficient of dynamic friction 25% lower than competitive lubricants, according to the company. The cream-colored gel dries to a slippery film that maintains its lubricity for several months. Non-toxic, non-flammable, and non-corrosive, it will not stain skin or clothing and cleans up with soap and water. It is available in 1-qt squeeze bottles; 1-gal, 5-gal, and 55-gal drums; as well as 1-qt and ½-gal bags.
Ideal Industries
Circle 257
Commercial utility vehicle
The Freightliner Sprinter commercial utility vehicle (CUV) is available in six different passenger-transporting models, 18 cargo models, and two chassis-cab models. Wheelbase dimensions of 144 in. and 170 in. are offered, as well as three roof heights, three gross vehicle weight ratings, and new gasoline or diesel engines. All models are standard with a 5-speed automatic transmission. The largest models offer up to 600 cubic ft of cargo space and 5,649 lb of payload capacity. According to the company, the online design service, eQuip, helps owners maximize the type of equipment for the interior work areas of their cargo or delivery CUV and to minimize the time it takes to have interior modifications designed and installed.
DaimlerChrysler Vans
Circle 258
Brackets
These low-voltage brackets feature reinforced ribs to minimize racking, side stabilizer tabs, cable tie ports to hold cable during trim out, countersink holes to prevent wallboard bow, and the Quick Click system to secure the devices without stripping out. The brackets can be mounted in new or “old work” applications, with or without Quick Click. New work brackets come in nail-on, face-mount, and screw-on styles; metallic swing brackets are available for old work. Their bright green color distinguishes them from line voltage boxes, and some can be used in dual voltage applications.
Pass & Seymour/Legrand
Circle 259
Fasteners/fittings
UL- and ETL-listed, this extended line of products features ground clamps, weatherproof pulling elbows, steel and malleable iron insulator support beam clamps, rigid conduit couplings as well as a range of accessories, including tie wire, jack chain, S hooks, and porcelain wire holders. All ground clamps are UL-rated for direct burial.
Orbit Industries/UMI
Circle 260
Adjustable mud ring
The Steel City adjustable mud ring ensures that stud-mounted outlet boxes fit flush with any thickness of finished drywall, plaster, or ceramic tile, according to the company. Features include an inner ring that adjusts from ½ in. to 1½ in. to accommodate various drywall thicknesses. Two adjustment screws enable the inner ring to be set at the anticipated depth prior to installation and adjusted after installation. Mountable to 4-in. square metallic deep outlet boxes, the device offers the rugged steel construction of a standard mud ring with enhanced flexibility.
Thomas & Betts
Circle 261
