Product News
Power quality analyzer The PA9Wireless power quality analyzer is designed for remote recording of electrical signals on low-voltage power lines. Because the analyzer incorporates a wireless modem, users can configure the unit remotely, view real-time data via the remote screen, and preview all recorded data without downloading the data. A large backlit LCD confirms setup information and real-time
The PA9Wireless power quality analyzer is designed for remote recording of electrical signals on low-voltage power lines. Because the analyzer incorporates a wireless modem, users can configure the unit remotely, view real-time data via the remote screen, and preview all recorded data without downloading the data. A large backlit LCD confirms setup information and real-time status, phasors, frequency, harmonics, harmonic power, voltage, current, per phase, total power/energy data, and minimums/maximums by phase.
Megger
Circle 150
Online UPS
The UniStar P Series single-phase online UPS is available in 6kVA, 8kVA, and 10kVA models to protect from outages and irregularities in incoming line voltages from 160VA to 280VA at 45 Hz to 65 Hz. Up to three modules can be installed in parallel for redundancy or additional capacity. According to the company, the product also features near unity input power factor, AC-AC efficiency greater than 90%, and less than 5% reflected harmonics.
Staco Energy Products
Circle 151
Surge protector
The Rayvoss standalone surge protector is available in single-phase, split-phase, 3-phase wye, and 3-phase delta configurations. In addition, the device can be installed directly to the internal bus bars, eliminating the voltage drop across a fuse. According to the company, this ability also provides lower clamping voltages and eliminates voltage surge when a fuse opens. Operating voltages include 120, 249, 120/208Y, 240/415Y, 277/480Y, 347/600Y, 240D, and 480D.
Raycap
Circle 152
freeproductinfo.net/ecm
Surge protector
The STV200/400K Series of surge protective devices (SPDs) offer surge current capacity of 200kA to 400kA per phase. According to the company, the SPD feature the industry's highest surge current repeatability, providing transient protection in all modes (L-N, L-G, N-G) and EMI/RFI filtering. The product also uses patented circuitry to monitor the status of all protection modes, including neutral to ground. Should protection be unavailable in any mode, the SPD's green LED will be extinguished, and the red LED will be illuminated. In addition, high isolation Form C dry contacts provide remote monitoring of suppression system failure, undervoltage, phase, and power loss. The standard enclosure is rated NEMA 12 with available options for NEMA 3R, 4, and 4X. Other options include a rotary disconnect, transient counter, and remote monitor panel.
SolaHD
Circle 153
UPS
The Digital Energy IT Series UPS is available in 600VA, 1,000VA, 1,500VA, 2,000VA, and 3,000VA tower and 19-in rack-mount models. In addition, the UPS features pure sine wave, fully digitized microprocessor-controlled automatic voltage regulation at 50/60 Hz and uses hot-swappable, user-replaceable batteries. Other product features include black-colored enclosures that allow front access, front-panel multifunction indicators, and additional communication slots.
GE Consumer & Industrial
Circle 154
