Product Spotlight
Rough terrain scissor lift The model 3394RT has a 33-ft platform height and 2,250-lb platform capacity. The load management system for the fuel-injected engine prevents it from bogging down in rough terrain conditions. The unit has a dual pump hydraulic drive and 3-speed selectable drive controls, and has been job tested at 45% grade.JLG IndustriesCircle 345 GFCI cord This in-line GFCI-protected triple
Sept. 1, 2002
JLG Industries
Circle 345
GFCI cord
This in-line GFCI-protected triple tap complies with OSHA regulations for GFCI use. It's rated 125V/15A, UL/CSA-approved for indoor or outdoor use, and rainproof rated. The 12/3 SJTW cord has an overall length of 3 ft, and the unit has an LED power light.
RDW Group
Circle 342
Truck caps
The Deluxe Commercial Unit (DCU) truck caps are made of rugged, fully welded aluminum frame construction. They are available with more than 200 options, including a variety of door and window configurations, colors, toolboxes, custom ladder racks, interior fabric liners, side panels, and overall cap heights. All DCUs feature Strattec lock cylinders in folding T-handles on all doors for added security, as well as Suspa gas props on all doors.
A.R.E.
Circle 346
Metal cutting circular saw
The model 6320 18V, 6.5-in. cordless circular saw has a 3,200-rpm motor for fast cutting. It cuts to a depth of 2.125-in. in one pass. The saw has aluminum upper and lower guarding and a durable nickel-plated steel shoe. The large lower blade guard lever is easy to access.
Milwaukee Electric Tool
Circle 341
Ratcheting crimping tool
Equipped with four color-coded die grooves, the YIMR full-cycle ratchet will accommodate a range of #8 to #1 Cu lugs and splices, and the related copper C-Tap connectors. The color-coded die wheel rotates matching die to a color-coded connector, embossing the completed connection.
FCI Burndy
Circle 340
Torpedo level
The 930-9 is a 9-in. level that features a rare earth magnetic base that is five times stronger than traditional strip magnets. The base firmly holds the level to iron and steel surfaces, freeing the user's hands for other jobs. The vials are framed with E-Z See, glow-in-the-dark material for easy, accurate viewing in dimly lit areas. No batteries are required.
Klein Tools
Circle 344
