Question: Does the NEC require a metal underground water pipe used as a grounding electrode to be buried a minimum depth?
See answer below.
Answer: No
Explanation: Section 250.52(A)(1) requires the pipe to be in direct contact with the earth for a minimum of 10 ft but no minimum depth is required.
John Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
