Code Quiz: Bonding & Grounding Requirements for Standby Generators
Test your NEC knowledge.
Based on the 2020 NEC.
Question: Does a standby generator installed at a building require bonding and grounding as a separately derived system?
See answer below.
Answer: It depends on the particular installation.
Explanation: The generator would only be considered a separately derived system if the transfer equipment contains a switching pole for the grounded (neutral) conductor. If the transfer switch contained a solid neutral pole, then it would not be considered a separately derived system. See Sec. 250.30 and the informational Notes in this section.
John Lupacchino
Senior Design Engineer
