Solar-powered outdoor luminaires
The SolarViper product line includes solar-powered, pole-mounted LED area, parking lot, roadway, and walkway luminaires. The luminaires are designed to consume from 10W up to 425W off-grid solar- power watts, with a minimum of five nights autonomy from stored power. Available in four light distribution patterns and five mounting options, the CSA-certified products place direct-downward, high color-rendition light and are Dark-Sky compliant. Features include sloped, flow-through vertical cooling fins on the underside of light-head surfaces to retard sediment or moisture buildup; a 100,000-hr lamp and electrical component life; and poles offered in aluminum, composite fiberglass, or galvanized steel.
SEPCO
