Considerations of Field LED Driver Replacement Published
This new white paper discusses issues related to the field replacement of drivers in LED lighting fixtures.
The National Electrical Manufacturers Association (NEMA) published NEMA LSD 74-2016 Considerations of Field LED Driver Replacement. This new white paper discusses issues related to the field replacement of drivers in LED lighting fixtures, and how several aspects must be considered to ensure that the replacement driver will function the same as the original driver.
Developed by the NEMA Ballast Section Technical Committee, NEMA LSD 74 is useful for the lighting industry and facilities management.
NEMA LSD 74-2016 may be downloaded at no cost on the NEMA website.
