DALI Alliance Issues Specifications for Wireless-to-DALI Gateways
The DALI Alliance (DiiA), the global industry organization for DALI lighting control, has published specifications for Wireless-to-DALI gateways that define how DALI lighting products can be incorporated into two widely used, non-DALI wireless ecosystems, namely Bluetooth mesh and Zigbee.
The new specifications are part of the DALI Alliance’s strategy to enable both wired and wireless connectivity for DALI, providing flexibility and creative freedom for lighting designers, OEMs, and system integrators. Many factors determine whether wired or wireless (or a combination of using both) is the best option for a project, so choice is key.
Wireless-to-DALI gateways provide the flexibility to incorporate DALI luminaires and other DALI devices into the control network, so it becomes very straightforward to add lighting capabilities alongside the other features of the wireless ecosystem. Existing DALI devices can be used with these gateways, and there is already an extensive range of certified and interoperable DALI-2 and D4i products on the market.
The gateway specifications enable well-defined and consistent lighting behavior.
Another key benefit is data and analytics. The gateway specifications enable DALI control gear to report luminaire, energy and diagnostics data (as defined in Parts 251-253) to the wireless ecosystem via the gateway, including lamp failure information.
The wireless network has access to data such as real-time energy and power usage, and diagnostics information including failure conditions and run-time data that can enable predictive maintenance.
“Publishing the specifications for Wireless-to-DALI gateways is a major milestone that signals our intention to allow DALI to operate within wireless networks when the need arises,” says Paul Drosihn, general manager of the DALI Alliance. “The move extends choice, convenience and creative possibilities to the user base of DALI wired systems and to those implementing new wired and wireless lighting control systems.”
Bluetooth SIG Chief Executive Officer Mark Powell says: “The standardized gateway between DALI lighting products and Bluetooth mesh lighting control networks will further accelerate the adoption of advanced IoT-enabled intelligent lighting systems. Providing valuable energy efficiencies and a more comfortable and productive experience for occupants, these sensor-rich lighting systems will also enable more efficient operation of other building systems, including HVAC and security.”
Chris LaPré, technology lead, Zigbee Alliance, adds: “The Zigbee-to-DALI gateway deliver[s] optimized and expanded wireless lighting solutions to the IoT market. When it comes to lighting-control networks, many of our members are invested across categories and applications, especially in the commercial space. We support broadening lighting possibilities as manufacturers drive standards that matter and deliver lighting solutions that keep the world connected.”
The two specifications published by the DALI Alliance are Part 341, covering Bluetooth Mesh-to-DALI gateways, and Part 342, describing Zigbee-to-DALI gateways. The specifications are available from the DALI Alliance website. The part numbers are aligned with the global, multi-part IEC 62386 standard for DALI technology. The specifications will be transferred to the International Electrotechnical Commission (IEC) for incorporation into IEC 62386.
Tests are already in development, which will enable gateways to be added to the DALI-2 certification program, providing interoperability between products from different vendors.
