Vertical grow light
The Arize Factor Multilayer Series of vertical grow lights packages improved optics and optimized light spectrums for indoor vertical farms. The series includes two versions: the Arize Factor ML900, a two-bar array designed to provide high light output for indoor cannabis growing; and the Arize Factor ML300, which features four-, five- and six-bar arrays designed specifically for optimized growth of densely packed leafy greens, herbs and microgreens. A custom light optic provides extra wide, uniform light dispersion over the grow area. There are three broad spectra options to select from, depending on the crop, along with multiple plug options available for connection flexibility and dimming capabilities.
