What Can Possibly Go Wrong, Part 2
When equipment failure interrupts production, a repair is performed so production can resume. But how soon after the failure does repair work begin? How much non-repair downtime transpires in the interim and how much does that cost?
Consider this scenario. A motor stopped running and will not restart. It’s almost break time, so the operator decides to report this after break. At this plant, supervisors request unplanned support from maintenance. The operator comes back and cannot find his supervisor, because she went on break and will be in a 30-min. staff meeting following that. So, an hour goes by before maintenance learns of the problem. The cost isn’t just the operator’s hour of pay for doing nothing. Everything made on this equipment sells, so any downtime is revenue lost forever.
In your plant, you may not have this exact scenario but your system of initiating a repair response may cause similar issues. A components manufacturer shrank their repair delay by equipping each operating area with a 2-way radio (with charger and spare battery) and assigning a maintenance crew leader to be “on call” with a radio on the same channel as the operators’ radio.
Mark LamendolaMark Lamendola
Related
Ecmweb 17180 Multi Craft Or Multi Screwup 0
