Unsafe Conditions Around De-Energized Equipment, Part 4
Just because equipment is de-energized and locked/tagged out doesn’t mean it’s safe to work on.
Have you considered these hazards, for example?
- Sharp edges. Stylish work gloves are increasingly commonplace. They help protect your hands from cuts and abrasions. As with other personal protective equipment (PPE), take preventive safety measures first. Visually inspect for sharp edges on and in the equipment you’ll be working on; if you cannot modify those edges (for example, file burrs away) cover them with something.
- Poor lighting. In new construction, you might not need to deenergize equipment because there’s no power run yet. The other side of that coin is the lighting tends to be poor. It’s often poor in existing installations, too. Consider running portable lights from a generator (for general illumination) or spotlighting the work with a portable, magnetic-mount work light.
- Fire hazards. Solvents, process chemicals, product packaging, and construction materials are some of the combustibles that you may encounter because they are not where they are supposed to be.
Mark LamendolaMark Lamendola
Related
workplace safety sign with phrases
