Sometimes, repairs back up and a queue forms. Servicing those on a first-come, first-served basis is a mistake.
In your computerized maintenance management system (CMMS), give each asset a repair priority score on a range of 1 to 100. Items that involve safety or the environment will range from 90 to 100; production assets will range from 1 to 89. When there's a queue, you can rank the order based on the priority score.
How do you determine the score? Ask production to help, considering revenue per hour and utilization. What is utilization? Here are two examples:
- The company can sell enough of Widget X each month to utilize 50% of production.
- The company can sell every Widget Y it makes.
Generally, you would let the Widget X machine sit if you must choose between the two due to resource constriction.
Keep the production team informed when a queue forms. They may tell you to bump something up, regardless of the priority score. For example, an item with low revenue and low utilization is for a potentially lucrative new customer.
Mark LamendolaMark Lamendola
