When Accusations Fly
How not to be part of the blame game
Ideally, all departments in a plant work together to solve problems and nobody plays the blame game. Some plants are that way, but what if yours isn’t?
For example, production misses this month's target. The production superintendent tells the plant manager machine utilization was low because maintenance has been lax with preventive maintenance (PM) and then taking too long with repairs. However, the reality is machine utilization would have been normal except for one incident in which an operator caused the downtime through human error. The time from maintenance notification to completed repair was less than expected, but the notification was delayed. When the plant manager asks you about the problem, you could rightfully blame the operator. However, that does nothing to prevent a recurrence.
A better approach is to say you must consider it to provide an accurate answer. Then, provide the documented facts of how that incident played out. For each deficiency, offer a solution. For example, maintenance could install a switch to prevent that error from occurring in the future.
