When Accusations Are Accurate
A lack of communication could cost you tens of thousands of dollars.
A critical line missed its production target, causing a late shipment. Between lost revenue and concessions to an upset customer, the cost totaled about $80,000. The production superintendent promptly blamed the maintenance department for a badly timed maintenance shutdown of equipment, claiming that waiting just one more day would have prevented the whole fiasco.
Maintenance did shut that equipment down for preventive maintenance (PM) work, so the accusation is accurate. It's also true that maintenance made good use of the downtime by performing two upgrades in parallel with the PM work, but received no credit for that uptime savings.
Production didn't alert maintenance that it needed an uninterrupted run for just one more day, so this seems like unfair finger-pointing, but is it? Not from the production superintendent's perspective. The normal condition of that equipment is it runs. He had no idea what maintenance was planning, and maintenance did not bother to ask about its customer's needs.
So, what’s the solution? Apologize for the communication lapse and implement a “check before do” step for future shutdowns.
