Electrical Troubleshooting Quiz — April 21, 2020
The plant has seven production buildings, A through G. In building C, the motor failure rate is nearly five times that experienced in the other buildings. You're being told this while interviewing for a newly created position as plant electrical engineer, after you asked the existing plant engineer, “What keeps you up at night?”
Now the bases are loaded, and you’re up at bat one more time. Can you hit a home run? Here's the pitch: All the motors are maintained the same way, so the error is not due to motor lubrication or other maintenance failures. Nobody knows where to look for the cause. What do you suggest?
Begin by asking what is different about Building C. Does it have a large non-linear load, such as a big motor, that starts across the line? Are there any other load differences? What is the nominal voltage at the service compared to that of the other services? Aside from lighting, does it have much in the way of single-phase loads? Are the single-phase loads distributed in a balanced manner, or is there excessive voltage imbalance?
What about the surge protection in that building? Does it even exist? If so, is it staged protection, or is an attempt being made to get by on a single device at the service?
Since this is an interview, ask if the plant engineer can take you out to look things over. You may find, for example, ground rods installed at motors, which is typically a sign of improper bonding. Also, listen for transformer hum.
Mark LamendolaMark Lamendola
Related
Quiz
dreamstime_l_92631939
