NEC Requirements for Wind Electric Systems
Article 694 of the National Electrical Code (NEC) provides the requirements for the electrical portion of wind turbine systems. Turbines continue to get larger, with longer blades and bigger nacelles. This means they are also taller, which makes access more physically challenging for the electrician. You’d better know your NEC requirements stone cold and have the required tools and materials when you climb up there. Climbing down and back up again is time-consuming and exhausting. Fortunately, not all the work is overhead.
Some key points include:
- If you install a maintenance receptacle powered by the turbine system, protect it with an OCPD that has a rating not exceeding that of the receptacle [694.7(E)].
- You can use the tower as a raceway, but only if it’s listed for that, evaluated as part of the listing, or evaluated for that and a field label is applied 694.7(F)].
- Apply overcurrent protection per Article 240 to the turbine output circuits, inverter output circuits, and storage battery circuit [694.15(A)].
- Using equipment bonding jumpers, create a unified bonding system between all exposed metal parts that are likely to become energized [694.40].
Mark LamendolaMark Lamendola
