Unsafe Conditions When Running Raceway — Part 3
Your work area may have the working clearances shown in the OSHA and NEC tables but still have inadequate working space. One reason is those table values are minimums. You’re expected to use good judgment when something indicates a need to exceed those clearances.
For example, you need to install a 75kVA transformer overhead. Obviously, you and your workmate Phil are not going to be able to lift it up there by hand. You need equipment (e.g., a lift) and space around that equipment for safe operation.
Working clearances can also be compromised by clutter. Many people seem to assume the clearances apply only to non-electrical factors, such as boxes stacked in your way by production people. Thus, if you have 4 ft of working space but you’ve left scrap (e.g., from cutting strut) all over it, how much safe working clearance do you actually have?
Your work in running raceway typically involves lifting, carrying, and ladder-climbing. Have you ensured your work area doesn’t present hazards of slipping and tripping when doing these things?
Mark LamendolaMark Lamendola
Related
Work Safety Construction
Conduit Raceway
