Unsafe Conditions When Running Raceway — Part 5
Although higher voltage batteries have allowed power hand tools to increasingly replace corded ones, portable cords are still run for most raceway work and can cause safety issues. To help prevent them, route power cords away from foot traffic paths (to avoid tripping hazards and cord damage), even if you must join two cords to get sufficient length. Where possible, route cords so their exposure to cutting shards is minimized. For example, instead of coiling up excess cord next to the threading machine, coil it up next to the outlet.
Wherever practical, use cord protectors to reduce the chance of mechanical damage to power cords. Cords can be damaged when items are dropped on them or when people step on them. Many people don’t know not to step on cords, but strategically placed cord protectors should prevent damage. However, those protectors won’t prevent damage from a lift truck rolling over them. Thus, if your cord must cross a lift truck path (e.g., major aisle in factory), used the appropriate devices to string the cord overhead instead of laying it on the floor.
Mark LamendolaMark Lamendola
Related
Work Safety Construction
Safety Words On Chalkboard
