Unsafe Conditions in Startup Testing and Commissioning — Part 2
Startup testing normally takes place in parallel with other activities. Construction is usually still going on, for one thing. Also, operators are on-site and running equipment. Operators may be engaged in actual production, performing training runs or performing live optimizations on processes and equipment.
Many times, the operators are new. They were hired specifically for this facility, and individual operators may not understand that other parties may need some specific equipment energized and others de-energized. They can easily interfere with your lockout/tagout.
In large facilities, such as electrical generating stations and paper mills, all this various activity has long been coordinated through a central desk or similar function. If you are engaged in startup testing and commissioning at such a plant, ensure your entire team understands the rules and procedures. For example, the central desk may require you to take an operator with you to hang a hasp and operations lock on equipment in Area X. For Area Y, that isn’t necessary (but next week, it may be required).
Mark LamendolaMark Lamendola
Related
Work Safety Guy In Plaid Shirt
Workplace Safety
