Restore or Modify?
When it comes to electrical parts, you may not much flexibility.
A repair doesn’t necessarily mean making something like new. Nor does it always mean replacing broken parts with new ones.
In a plant that extruded small plastic pieces, two arbors broke within a few months of each other. The first one was put back together with the epoxy JB Weld, and the seam was sanded smooth. The other one was normally subject to much more vibration, plus the stress would be along the fracture joint; it was replaced.
With mechanical parts, you often have that kind of leeway. With electrical parts, not so much. Modifying electrical parts usually alters the listing for the part or equipment, and that is barred by the NEC. For example, you would not repair a 120V switch even if you could.
However, some mechanical things that fall under the purvey of electricians can or should be modified. For example, any time the mechanical execution of the work [110] is substandard in appearance, you may want to redo it. If it is substandard in functionality, you should redo it.
