Unsafe Conditions in Startup Testing and Commissioning — Part 3
Working with outdated drawings can be lethal. Ensure you have some kind of “controlled drawing” system.
At one time, start-up techs reviewed D-sized drawings “in the trailer” before starting a particular test, and then carried C-sized drawings with them. One typical way this worked is you would get a date/revision stamp on your paper drawings. At the start of each shift, you would check your drawings against the latest paper drawings hanging on “the central rack” to ensure you were working with the latest revision. Because you were marking up your drawings as your work progressed, you did not want to replace them unless you had to.
Today, we have a combination of cloud-based systems for storing drawings and mobile devices for accessing those drawings. Depending upon the system, the drawings can be field marked. Ideally, a “field copy” will be field marked.
Review whatever system you have, and make sure it allows field personnel to easily compare “their” revision to the current one, read engineering change notes, store field markups, and submit change requests.
Mark LamendolaMark Lamendola
