Electrical Troubleshooting Quiz — Nov. 3, 2020
You’ve been the electrical maintenance manager at your plant for about a year. You and your boss have discussed a “thorn-in-the-side” issue for several months. The plant has a lot of fiber optics, and one circuit or another seems to have a problem every week.
The plant has a contract with a firm that handles the trouble calls. They send a different tech every time, and each tech tells a different story about the problem. You’ve seen many cables repulled and many fiber-optic devices replaced. Sometimes on the same node or circuit, a given cable or device gets replaced with each visit from a tech. It seems like they don’t really know what they are doing, and the downtime is expensive.
What can you do?
Optical power meters are inexpensive — a decent one costs under $30. You can buy an optical fiber fault detector cheaply; it works similarly to a time domain reflectometer (TDR) for copper cables. But instead of measuring the reflected electrical signal against time to locate a fault, it does that with a light signal.
Obtain both instruments and then:
- Take baseline optical power data at each fiber connection; keep the data in the CMMS.
- Test all optical fiber cables; replace any marginal ones.
For the devices, build (or buy) a test rig for those that are widely used in the plant. For example, if you have 24 fiber optic converter cards, then build a rig that powers one card, includes a controllable light source, and has an output meter.
With these tools, you can check what the techs report. You can even avoid calling them in the first place.
Mark LamendolaMark Lamendola
Related
dreamstime_xxl_178911059
dreamstime_l_63221258
