Is Your Breaker Maintenance Broken?
Don’t ignore this important practice.
Breaker maintenance practices at most production facilities range from nonexistent to ineffective. Sometimes, they are completely off the mark.
A plant engineer at a multi-building manufacturing plant said its breaker maintenance program was “excellent.” The program consisted of opening 120V distribution panels and using an infrared spot thermometer to check the front of each breaker. It did not include any testing or maintenance of breakers operating at higher energy levels — not even those critical feeder breakers.
Given limited resources, it usually makes sense to let small breakers at the user end of the power distribution system run to failure. However, if you are going to check them, then conduct a proper thermographic survey.
At the other end of the power distribution system, it’s a different story. These breakers handle far more energy than 120V breakers used for office convenience receptacles do. Main breakers and feeder breakers should be subjected to the recommended testing at the recommended intervals. This is to prevent catastrophic failure due to failure to operate or revenue loss due to nuisance tripping.
