Is Your Feeder Maintenance Starving?
A feeder cable fault can produce catastrophic damage (recovery is impossible). The fireball and arc blast resulting from a phase-to-ground fault can kill nearby personnel, and then render a plant unusable for weeks while repairs are made. The prospect of repairs taking that long before restarting often results in the decision to close the facility — especially when it’s a manufacturing plant.
Yet, in only a few industries is it normal to follow the IEEE and ANSI standards for feeder cable testing. The testing practices are based on facts such as:
- Cable insulation deteriorates over time.
- Comparing cable insulation condition over time to a baseline condition assessment allows you to predict cable failure, barring an unusual event such as unexpected mechanical damage or lightning.
- Replacing deteriorated cables during a scheduled shutdown costs less than replacing failed cables during an unplanned shutdown.
- Planning a cable replacement gives you time to obtain the correct materials, set the job up properly, execute the work carefully, and take baseline test data when it’s done.
