Unsafe Conditions in Start-Up Testing and Commissioning — Part 8
If an existing site has start-up testing, the typical situation is the plant has active processes (operations are not shut down). Operators who are unaccustomed to contractors on site may see you as being in their way rather than as someone they might put in danger. To avoid this mindset, meet with operators in the affected area and ask them to point out dangers you might encounter. In response to this, their thoughts should go to their own actions and what they can do to help protect you.
If a green site has start-up testing, then the typical situation is other trades are working in the same space or near it. Any halfway decent contractor firm will take safety seriously. Unfortunately, that low bar is too high for some. They may do things like string portable cords across stair steps, weld without screens, or take a shortcut through your roped-off testing area (and even walk on your test leads). Report any unsafe actions to the general contractor’s safety manager.
Mark LamendolaMark Lamendola
Related
Work Safety Guy In Plaid Shirt
Work Safety Notebook Hard Hat Construction Supplies
