How Is Your Power-to-Weight Ratio?
Strip away excess weight to gain resources for high-priority equipment and tasks
Dec. 15, 2020
Why do Funny Car drag racers strip out seats and many other items from their vehicles? They do so to reduce weight, because the rules of the sport limit engine power. These rules are intended to keep costs down, making racing possible in the first place.
Similarly, corporations place limits on maintenance budgets. You never see a 100,000-square-foot maintenance shop with 190 maintenance techs supporting a 50,000-square-foot manufacturing plant with 100 operators.
If you are at the other extreme, where it can sometimes seem as though executives expect world-class maintenance on a shoestring budget, follow the Funny Car racer example.
First, conduct an ROI assessment on equipment. You can probably eyeball this for most items. For example, a line that produces less than 5% of the plant’s revenue likely has a low maintenance ROI.
Next, conduct a needs assessment on tasks. Why are you performing manual vibration PMs when you can install monitors instead?
Once you’ve stripped away the excess weight, you will have more resources to apply to high priority equipment and tasks.
