Common Repair Errors to Avoid
Mistaken identity and unneeded adjustments are two culprits.
In manufacturing, the typical repair job consists of identifying and replacing the failed part. This includes things like motors, breakers, fuses, and sensors. The two most common errors are identifying the wrong part as the problem and replacing a part with one that is incorrect for the application or not in serviceable condition.
A repair job might consist of making an adjustment rather than replacing something. The most common error is to assume an adjustment is needed and just start adjusting. Always take as-found data, understand what each adjustment does and how the adjustments interact, and take as-left data when done.
A repair job might consist of redoing something, for example a bolted connection that showed hot on an IR scan. Redoing a bolted connection is better than tightening it, but to redo it correctly you need all new fasteners. Once you tighten a bolt, you have stretched it and permanently deformed it. Loosening it and tightening it again to the same torque will not give you sufficient clamping.
