CMMS Repair Procedure Usage Reporting
A code to cover repairs for which there isn’t a specific procedure
If your maintenance system is set up properly, you have specific procedures for the most common repairs as well as for highly technical ones. You probably don’t have a repair procedure to cover how Bruce solved an unstable control problem by moving the signal wire away from power conductors. That situation will seldom come up and will never repeat on that equipment. No reason to write a procedure for a “one-off.”
You should be able to go into your CMMS to generate a report of repair procedures used in a specific period (e.g., past 90 days), and then sort by the number of uses for Pareto analysis. But what about Bruce’s repair, which doesn’t have a procedure? To solve this dilemma, have a code to cover any repair for which there is not a specific procedure. The repair tech might select “craft capability” from the list.
The Pareto analysis can identify repairs that would be eliminated by identifying and addressing the root cause. The huge cost-savings of this technique makes it worth the effort.
