Reducing Costs with your CMMS — Part 2
Use you CMMS to compare asset profitability.
It’s common to use a CMMS for asset management. Each asset has a unique asset number, and you assign maintenance tasks (predictive, preventive, etc.) to that asset to keep it in good shape.
With this mindset, you don’t choose between assets and perhaps misallocate resources. Consider two production lines, A and B. Each is composed of assets. Is a 20-hp motor on Line A as valuable as a 20-hp motor on Line B? To answer that, you need to know the revenue produced by each line. Operations has that information. A more accurate analysis would use the profit per line, but operations probably does not have that information.
If Line A produces $200 of revenue per hour and Line B produces $50,000 of revenue per hour, then the comparison leaves no doubt. Prioritize the allocation of limited maintenance resources to where they produce the most revenue. If the controller says to cut costs by 10%, turn to your CMMS to see the value figures and cut costs on assets of lower value.
