Electrical Troubleshooting Quiz — May 18, 2021
Stop unscheduled shutdowns with a Pareto Analysis
A production line of moderately high importance (number 8 among 22 lines for revenue) has been modified numerous times over the years. Many of the mechanical parts, such as arbors, brackets, and travel rails, have been made in the machine shop.
Controls also have been fabricated and retrofitted to this line, including proximity switch-actuated doors and dampers, temperature-controlled fans, and line speed controls that interact with VFD-controlled motors. The line has undergone several PLC upgrades.
There were good reasons for all these modifications, but they are poorly documented. Some are documented with only hand sketches and notes on paper. Others have some rudimentary CAD drawings available. The preventive and predictive maintenance procedures are similarly sketchy.
Over the past few months, this line has had an excessive number of unscheduled shutdowns due to the failure of some component or subsystem. How can you get downtime back under control?
You need to conduct a Pareto Analysis on the downtime failures. Put them on a set of spreadsheets that you can sort by frequency, subsystem, failure cause, PM tech, and repair tech.
Now you can analyze and characterize the failures. You will probably find one cause that stands out across all subsystems; perhaps, by frequency, it accounts for 80% of all failures.
Or perhaps one subsystem stands out as the primary point of failure. If you impose one analysis on top of another (perhaps using a line display versus a bar display), you may find a correlation between one type of repair and two repair techs versus that repair and all the other repair techs.
Focus on the problems that stand out. Solve for cause and correct deficiencies in the documentation related to the problem.
