Grounding Frequent Flyers
How do you know if a given repair is required too often? In the typical maintenance organization, this determination occurs only when someone happens to connect the dots; it’s not actively looked for. When someone does connect the dots, there may be acknowledgement that, “Yeah, it seems like we’re doing this a lot,” but considerable time will pass before the cause is addressed.
First, you must actively search for the problem. From your CMMS, generate a report listing the last 100 repairs. Sort them by type and then by asset number. Now you can easily see any patterns if they exist. If you don’t see any, then go with a larger data sample.
Next, identify the three most common repairs and the 10 assets with the most repairs.
- For each of these repairs, what is the failure cause? Can a change in design, PdM, or PM eliminate that cause?
- If any asset is similar to other assets not on the list, then that asset needs attention. Maybe it’s an operator issue. If you see repeats on the list, then there is likely a root cause to determine.
Mark LamendolaMark Lamendola
Related
Prioritizing Repairs 1 2 3
