Preventing Time Bombs
Repair jobs usually start off as a mystery, with the technician using a troubleshooting process to determine how to fix the problem.
Repairs are often done under time pressure, which increases the likelihood of an error. Compounding the problem, a repair job is seldom clearly delineated. It usually starts off as a mystery, with the repair technician using a troubleshooting process to determine what needs to be done to fix the problem. The tech may not have encountered this particular problem before, so the whole job is a learning experience. And with so much unknown, the repair tech cannot even look up the answers.
Compare this to the typical preventive maintenance task, which is clearly delineated and repeated many times. The tech conducting his 12th motor maintenance PM knows what to do, but the tech responding to his 12th motor failure call is probably working his 12th one-off job.
Any repair should start with taking “as found” data and end with taking “as left” data. Photographs can help with this. For at least your critical equipment, you should have a repair procedure. Ensure it includes a post-repair checklist designed to catch errors made during the repair. Ask your techs to supply ideas for this checklist.
