Electrical Troubleshooting Quiz — Sept. 21, 2021
A production machine takes three tries to start because of the motor. How can you solve this?
You’ve received a complaint about a particular production machine. The production supervisor meets you at the machine to discuss what’s going on. The problem is it won’t always start. A sign is posted that says to wait 5 min. between starting attempts to prevent burning out the drive motor. It often takes three tries, which wastes 15 min. of the operator’s time and costs 15 min. of production time.
The supervisor would be fine with needing a second attempt on rare occasions, but the team can’t be wasting 15 min. every day.
They’ve already implemented a pre-start check to ensure no parts are in the system when a start attempt is made. Once the motor starts, everything works fine, so that rules out any gross misalignment, parts jams, etc. How can you solve this?
It almost sounds like the motor needs to warm up because it starts eventually. Perhaps simply allowing two attempts before a 5-min. wait will fix the time waste issue; measure the motor temperature before trying.
Perhaps the wrong grease is being used or the motor is overgreased. Determine the correct lubricant, and use the recommended procedure to lubricate the motor properly. Apply the same logic to the gearbox, which might be using the wrong gear oil. Replacing older paraben-based oils with synthetic oils in both places will eliminate several issues that may contribute to this problem.
Or perhaps the motor is the wrong one for the application. It might be an incorrect NEMA design or the wrong size. It might also be defective. To find out, test the motor to see how much starting current it needs while uncoupled from the load.
