Help from Operators
In some facilities, operators play a critical role in repairs. In other facilities, they don’t know they can help, and they wouldn’t know what to do if they tried to help. These operator functions have assisted some facilities in slashing repair times:
- Provide a brief, accurate description of the observed problem.
- Prepare the equipment and the area around it for the repair. For example, remove work in progress, move materials out of the way, move portable lighting to the work area, etc.
- Assist with lockout/tagout. This does not mean simply hanging the electrician’s lock.
- Jog the equipment forward or backward upon demand.
- Liaise with management so the technician can focus on the job. This is especially helpful in facilities where “management by hovering” is a problem.
Operators can also help by not distracting the repair tech with idle chitchat.
Not all of these functions are a fit for each situation. And one or more not mentioned here might be helpful for a given piece of equipment in your facility.
How can you move forward with this idea in your facility? A good approach is to suggest a pilot program. Determine the revenue per hour from a critical system. Maybe Line C produces $350,000 per hour and even at 100% output that production gets entirely sold. This means each minute of downtime is about $5,800. If an operator can help in a way that saves 10 minutes, that’s $58,000.
Offering management a way to add $58,000 of revenue is much more appealing than just saying maintenance could be faster with some help from the operator. To get at the actual time savings and, thus, dollar savings, list all the things the operator could reasonably be expected to do. For each item, estimate the time savings.
Mark LamendolaMark Lamendola
Related
Maintenance Crunch Time
dreamstime_xl_110795241
