Electrical Troubleshooting Quiz — Nov. 19, 2019
A few years ago, an addition was made to the plant. This addition contains three heavily automated lines. They are like older lines, but have robotics replacing manual operation tasks, such as lifting sheet metal blanks into the feeder tray.
All three lines ran reliably until last year. Then, one of the four 30-hp motors on Line Two failed. The motor was replaced and sent to a motor shop for analysis. The shop reported the motor had spun a bearing, which is what the electricians who removed it had said.
Shortly after that, the main board of a controller on Line One smoked out. Other failures have occurred periodically since then. What is going on?
These failures indicate damage from at least one transient event. To prevent future events:
- Install soft starts or VFDs on larger motors to prevent “across the line” starting transients.
- Analyze your transient voltage suppression system (TVSS) against current engineering standards (e.g., make it multi-stage).
Ask that motor shop if they have kept any records that show evidence of bearing pitting. If so, you have inadequate bonding. And thus, undesired current is flowing through motor bearings and electronics.
Fixing the bonding and TVSS should prevent further damage. But what about the damage already done? Keep in mind that interrupted production is orders of magnitude more expensive than scheduled repairs are. It is probably cheaper to replace all controllers and other electronics, rather than to let them run to failure. Perform ultrasonic testing and thermographic imaging to find other looming failures.
