Ending Echo Failures
Tips on how to stop a chain reaction of equipment failures
In a production facility, it's not the cost of repair or replacement that matters. It's the cost of the downtime. This is true for most types of facilities (think hospitals, for example).
It's nice that an ace troubleshooter can quickly diagnose the problem and restore the system to running as it did before the failure. But what other components were stressed by the event that caused the downtime? And is the equipment's current design truly a match for the demands now placed on that equipment?
When other failures follow the first one, we can think of them as echo failures. For example, a transient voltage event destroys a circuit board in the control panel of Line B. That same transient may have damaged motor bearings, motor windings, power conductors, control wiring insulation, sensors, and other components of the system.
To prevent these echo failures, you must conduct a comprehensive post-failure analysis. Not just of the failure, but of what didn't (yet) fail. Due to limited resources, you must prioritize based on:
  • The cost of downtime for a given system.
  • Likelihood of failure for a given component.
  • Your predictive maintenance capabilities (e.g., you have ultrasonics for predicting bearing failure).
