Handling Preventive Maintenance (PM) Backlogs
If your PMs are scheduled correctly, then you are doing just enough PM work to take corrective action before emerging problems significantly degrade equipment performance and/or interrupt operation of that equipment. This means that getting behind schedule on PMs increases the likelihood of equipment degradation or failure. Simply staying behind isn't a practical option.
Unfortunately, many things can cause you to fall behind on PMs. Two big causes are personnel changes and unplanned downtime, both of which hold clues for catching up:
- Re-evaluate and streamline PM procedures to eliminate unnecessary steps.
- Hire a contractor to supplement your workforce, performing a specific project that would otherwise occupy your people.
- Invest in better tools and test equipment to increase worker efficiency.
- Invest in training so people are not only more skilled, but also feel more valued.
- Contract out a predictive maintenance (PdM) project (e.g., ultrasonic bearing analysis) and the repair work for the problems found.
