A survey conducted in 2018 showed the average age of an electrician was 58, which is a year older than a 2016 survey by the same group showed.
Let’s assume an average-age electrician started trade school right after high school and joined the trade at age 20. That’s 38 years in the trade. If this person has worked in industrial maintenance this whole time, they have seen considerable change in how motors are maintained today versus in 1982.
In 1982:
- Perform voltage measurements quarterly; look for voltage imbalance or phase loss. Replaced by line monitoring.
- Conduct insulation resistance testing annually. Replaced by automatic insulation resistance testing.
- Test for total vibration, quarterly. Typical method was to feel by hand. Replaced by vibration monitoring that can break down the actual signature for intelligent analysis.
- Touch the motor (quickly!) to test for heat. Replaced by using a thermograpic camera.
Aside from changing the grease (annually or longer), are you still doing things in the old, inefficient ways?
Mark LamendolaMark Lamendola
Related
Promo Pic Basic Training Jan 2021
dreamstime_m_99644332
