• NEC Rules for Pools, Tubs, Fountains, and Spas ― Part 3
    Summing up the requirements of Article 680, Part III
    Aug. 20, 2019
    Article 680, Part III provides the requirements for electrical equipment associated with storable pools, spas, and hot tubs. Some highlights:
    • All equipment must be GFCI-protected [Sec. 680.32].
    • If an underwater luminaire is installed, it must be in or on a wall of the pool, spa, or tub [Sec. 680.33].
    • If the underwater luminaire is within the low voltage contact limit, it must be part of a cord and plug connected lighting assembly. And it must meet all four conditions of Sec. 680.33(A)(1) through (4).
    • If the underwater luminaire is over the low-voltage contact limit but not over 150V, it can be part of a cord and plug connected lighting assembly. And it must meet all five conditions of Sec. 680.33(A)(1) through (5). The fifth condition is compliance with Sec. 680.23(A)(5).
    • A condition common to both types of luminaire are “No exposed metal parts”, [Sec. 680.33(A)(1) and (B)(1)].
    • Receptacles must be at least 6 ft from the inside walls of a storable pool, spa, or hot tub [Sec. 680.34].
    • Receptacles within 20 ft of the pool, tub, or spa must be GFCI-protected.
