Staying Safe on Stairs
Three tips to help avoid stairway injuries
Feb. 19, 2019
When it comes to stairways, familiarity breeds complacency. Perhaps, for example, you like to run up or down a stairway. What happens if you lift your foot just a little shy of high enough, and catch your shoe on the edge of a step? You suddenly pitch forward; you could be severely injured. If you walk up and down steps, you don’t have that strong forward momentum so correcting for a “foot catch” is easy.
Three tips to stay safe on stairs:
  • Avoid carrying objects that are bulky and/or heavy. These complicate your balance and can make it hard for you to see where you are placing your feet.
  • Where practical, use battery-powered power tools instead of corded tools. Doing so eliminates issues with routing, securing, and covering power cords.
  • If you do use corded tools, don’t run the cords across steps. Route them along the outside of the stairs or off to one side if it’s not an open stairway.
