Symptoms vs. Causes
As a rule of thumb, use the "Five Whys" method to make the repair process quicker.
Sometimes, it's hard to tell the difference between a symptom and a cause. This is especially true when you're under the time pressure of performing a repair.
Root cause analysis can prevent recurrence. But how much effort should you put into it? Does every repair tech have the training, time, and aptitude to perform a complicated root cause analysis? (That's a rhetorical question).
Are there some easy rules of thumb that can make the process quicker, even if less precise? Do you need or can you afford total precision in all cases? (Another rhetorical question).
Yes, there are some easy rules of thumb. For example:
  1. Look for what has changed.
  2. Ask the operators.
  3. Use the “Five Whys” method.
What is the “Five Whys” method? Here's an example:
  1. The motor vibrates badly. Why? It spun a bearing. Before replacing the motor, you ask the next question.
  2. Why did it spin a bearing? Looks like arcing damaged the bearings.
  3. Why was there arcing? Undesired current flowed through the motor.
  4. Why did current flow through the motor? The motor wasn't properly bonded.
  5. Why wasn't it? The installers didn't connect it to the EGC. You found the root cause. Now when you replace the motor, you will also connect it to the EGC.
