Temporary Repairs
Four ways to keep temporary repairs from becoming permanent
Sept. 3, 2019
Temporary repairs, sometimes referred to using the famous brand name of an adhesive bandage product, are a fact of life in production facilities. Temporary repairs are typically made for business-driven reasons, such as delivery pressures and resource utilization (e.g., not having operators idle).
The repairs may involve using bypass jumpers, the wrong type fuse or breaker, a custom-machined (“jury rigged”) part, or some other means. In a Midwestern plastics plant, a failed E-stop was replaced with a normal stop switch until a new E-stop could be obtained later that day.
The main problem with temporary repairs is they tend to become permanent. To prevent this, you need a special process for them. It should include:
  • A form that Operations must sign before the temporary repair will be made. They agree to provide downtime as soon as you have what you need to affect the correct repair.
  • Local notice (e.g., a sticker) identifying equipment with a temporary repair.
  • CMMS work order for the proper repair. It should provide an alert periodically (e.g., twice a day) until the repair is completed. The response to the alert is to check the progress on obtaining the parts or whatever else is needed.
  • A means of ordering the needed parts/services/materials on an expedited basis.
