Unsafe Conditions Around Energized Equipment
The unsafe conditions that you might encounter with de-energized equipment also exist with energized equipment. But with the latter, you have additional hazards.
Consider these, for example:
- Outdated drawings. Those field modifications can radically change the safety equation, if the drawings that are stowed in the equipment cabinet don’t reflect the modifications. Printed drawings should have an expiration date, by policy. If your company doesn’t have that policy, get new drawings before starting the project.
- Unguarded electricity. Even non-contact work like thermography requires removing the covers that help protect you from arc blast. Remove only the cover(s) and open only the door(s) needed to do a specific task. Replace (or close) immediately after that task is complete.
- Unguarded other energy sources. Batteries, capacitors, gas cylinders, and hydraulic systems are just some ways energy can be stored. If you’re exposed to any of these additional sources, take additional precautions. For example, how do you protect yourself if you’re working right next to power factor correction capacitors?
